ross teck
A 58 plate car won't work with an iPhone whatever you try as the Bluetooth module is rSAP only and the iPhone uses the HFP protocol. They started using different Bluetooth modules from MY11 onwards (mine was built October 2010 and is a MY11 car). When I was looking for my car I knew if I bought a 10 plate I'd have to factor in the £100 or so for a replacement module. In the end I settled on my 60 plate car.
The only way to get your iPhone working is to replace the Bluetooth module under the driver's seat with a newer one. As Rustynuts says your Bluetooth module looks to be faulty anyway so maybe not too bad having to buy a replacement anyway.
Have a look through the sticky/pinned post at the top of this section for full info. ;)
The part number of the Bluetooth module he's fitted is 3C8-035-730-E which is HFP and RSAP compatible.
Good spot.... I'd not seen that. :)
Are you saying then that the module I've fitted is faulty if so how can I check this out, I've been in touch with the company I bought it from and they a sure me it is brand new and I carn't dispute this as the date of manufacture is very clear on the module, they stopped making it in 02 2015 regardes oldtimer
Okay, had a bit of a google this morning and found this thread which has similar issues.
http://www.briskoda.net/forums/topic/191478-telephone-errors/
Lifted from that thread the long coding for the telephone module was changed to 0200000001010110 which cleared the last of the fault codes, so perhaps try that. In any case, it would appear that it is a coding issue so perseverance would be an idea. Don't forget to make the Workshop Code, Importer and Device number change as above.
Edited by Rustynuts
That's brilliant i will have ago this evening after work ,ps it looks like someone else doesn't sleep
I don't have time to sleep. Well, not for very long anyway. :D
I'm not 100% sure, but it sounds like your car had a factory fitted bluetooth module that's been replaced for a 3C8-E and you've also fitted a Columbus.
If that's true, you probably don't have wiring for Columbus voice control or stereo bluetooth modules.
If you want to check, you need to look at connector C (possibly green) on the quadlock to the Columbus:
- Pins 1, 4, 7, 9 need to be used for Columbus voice control
- Pins 5 and 11 need to be used for stereo bluetooth
I would expect all six pins to be empty...
For the bluetooth module, I would suggest 020000000100010000000101 and fill in the Workshop Code, Importer and Device number as mentioned by Rustynuts. This should clear two of the errors. You'll still have "9457427 - Left audio channel for speech/telephone" as you're missing wiring for the left channel.
As for the Columbus, I'd try coding it to 04000400040400830000. This should disable microphone monitoring, disable voice control and set the EQ for a superb. Once you change this lcode the unit needs to be reset by holding the <, > and mic buttons on the Columbus.
Assuming both codes are accepted, I'd then clear all error codes afterwards and hopefully you'll just have the left audio one remaining.
right were to start i've checked at the back of the columbus the green connector as 2 wires coming out no 6 12 tel + tel- one is blue the other is white ,so i have coded the bluetooth module as you suggested and it took the code now for the columbus i took this to come under radio and
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: TMBBF73T799016257   License Plate:
Chassis Type: 3T (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 62
          72 77
VIN: TMBBF73T799016257   Mileage: 49890km-31000miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BK    HW: 03L 906 022 GA
   Component: R4 2,0L EDC G000AG  2848
   Revision: 13H01---    Serial number:
   Coding: 0000078
   Shop #: WSC 33361 790 00999
   VCID: 6FED9F287EE5AE4697-803A
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 050 T    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1812
   Revision: 04843012    Serial number: 00000808291160
   Coding: 0000020
   VCID: 2345A318E2AD5A2643-8076
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 3T0 907 379 A    HW: 3T0 907 379 A
   Component: ESP FRONT MK60      0102
   Revision: 00H11001
   Coding: 0006786
   VCID: 3B757B787A1D02E66B-806E
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 N    HW: 3T0 907 044 N
   Component: Climatronic   122 0102
   Revision: 00003001
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 3D717560AC090CD655-8068
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 A    HW: 1K0 937 087 A
   Component: BCM PQ35  H+  020 0358
   Revision: 00020000
   Coding: 40990AB8DC65F1C04008008111008FE403111BAE632085605C4040000000
   VCID: 2F6D5F287E65EE46D7-807A
   Subsystem 1 - Part No: 3T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 26080  22  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 220908 05  54  0402
   Coding: 0730ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 165
                    Mileage: 49788 km
                    Time Indication: 0
                    Date: 2010.10.26
                    Time: 09:26:57
             Freeze Frame:
                        Term 15 On
                    Voltage: 10.35 V
                        ON
                        ON
                        Term 50 On
                        ON
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475     HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0003
   Revision: --------    Serial number: 66640824701186
   Coding: 000104
   VCID: 7EF3B26CE98FD7CE0C-802A
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655     HW: 3T0 959 655
   Component: J234__LAJ VW10 HI   1815
   Revision: 17013000    Serial number: 003CCPJPKCA9
   Coding: 0016714
   VCID: 7EF3B26C298FD7CE0C-802A
   Subsystem 1 - Serial number: 6333FTS613722528
   Subsystem 2 - Serial number: 6343FTS614082528
   Subsystem 3 - Serial number: 6353ETS66AESUVNP
   Subsystem 4 - Serial number: 6363ETS6UQQJUVNH
   Subsystem 5 - Serial number: 6373JTS6LJRGUVNH
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           055 0111
   Coding: 0001731
   VCID: 76E3AA4C01BF9F8E54-8022
   Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0011
   Coding: 00000130
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 940 D    HW: 3T2 920 940 D
   Component: KOMBI         H28 0024
   Coding: 410D00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 35616D409439D4969D-8060
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K089050295
   Coding: EDA1FF064006023303
   VCID: 35616D405C39D4969D-8060
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 49802 km
                    Time Indication: 0
                    Date: 2010.10.26
                    Time: 16:29:42
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H28 0024
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000003
   VCID: 72EB965C6DD783AE78-8026
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 G    HW: 3T0 035 680
   Component: RNS-MID       H50 5274
   Revision: AB001001    Serial number: SKZ6Z7L8151055
   Coding: 04000400040400830000
   Shop #: WSC 12345 123 12345
   VCID: 346750449743CD9EAA-8060
   Subsystem 1 - Part No: 3T0 051 859 AL
   Component: EU West V13  8348
2 Faults Found:
00857 - CD Changer Unit (R41)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 67
                    Reset counter: 169
                    Mileage: 49768 km
                    Time Indication: 0
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 14
                    Reset counter: 131
                    Mileage: 49849 km
                    Time Indication: 0
                    Date: 2010.10.27
                    Time: 14:58:07
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 A    HW: 7N0 959 793 A
   Component: TSG FA        H03 0190
   Revision:             Serial number: 0000100274630
   Coding: 011D0220DE01121002
   VCID: 408F0C94D3FB613E3E-8014
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 196    2301
   Revision: 00H15000
   VCID: 2A5B4E3C85878B6E00-807E
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 A    HW: 7N0 959 792 A
   Component: TSG BF        H03 0190
   Revision:             Serial number: 0000100233966
   VCID: 3F8D0F68AE051EC647-806A
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0133
   Revision: 00H04000    Serial number:
   Coding: 1377095
   VCID: 346750445743CD9EAA-8060
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    S004
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    S004
   Coding: 00000021
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 67
                    Reset counter: 169
                    Mileage: 49768 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 14
                    Reset counter: 131
                    Mileage: 49849 km
                    Time Indication: 0
                    Date: 2010.10.27
                    Time: 14:58:07
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-795.clb
   Part No SW: 7N0 959 795     HW: 7N0 959 795
   Component: TSG HL        H02 0190
   Revision:             Serial number: 0000100272504
   Coding: 010C00200001221002
   VCID: 0109C9909871A83671-8054
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794     HW: 7N0 959 795
   Component: TSG HR        H02 0190
   Revision:             Serial number: 0000100268426
   VCID: 55A1CDC03C79F4967D-8000
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105234457
   Coding: 020000000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_SE36.rod
   VCID: 2541BD002499A4162D-8070
2 Faults Found:
          B104F 13 [009] - Short to GND
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 129
                    Mileage: 49689 km
                    Date: 2016.05.30
                    Time: 11:59:27
9457171 - Right audio channel for speech/telephone
          B104E 13 [008] - Short to GND
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 169
                    Mileage: 49849 km
                    Date: 2016.06.06
                    Time: 03:19:20
End-------------------------(Elapsed Time: 03:09)--------------------------
coded that hope i'm explaining it clearly i've took a scan if i've done it wrong i'm sure you will tell me
Are you sure you cleared all the fault codes after recoding and restarting the Columbus with the three button method?
These are the errors you still have and most have non-current mileages.
  00446 - Function Limitation due to Under-Voltage Mileage: 49788 km
  01044 - Control Module Incorrectly Coded Mileage: 49802 km
  00857 - CD Changer Unit (R41) Mileage: 49768 km
  01523 - Microphone for Telephone (R38) Mileage: 49849 km
  9457427 - Left audio channel for speech/telephone Mileage: 49689 km
  9457171 - Right audio channel for speech/telephone Mileage: 49849 km
To clear them all you can use the 'Clear all DTCs' in the 'Autoscan' section then rescan. I would expect almost all should disappear apart from the left audio channel.
Dar how stupid of me no I didn't do that tonight got called out on breakdown let you know with scan oldtimer
as promised the latest scan after clearing fault codes an taking car out ,I can now use iphone with voice command and people can hear me as i  can hear them,not sure if there is a microphone but the sound seems  to come from front right speaker, But its nice to use the iphone and keep the columbus I bet there is a lot more that can be done ? So can i say a very big thank you to rustynuts uber member  and some other members who finely solved a long running saga getting the iphone to work??? agine gold stars to all that help oldtimer       Tuesday,07,June,2016,19:14:21:30882
www.Ross-Tech.com
          72 77
VIN: TMBBF73T799016257   Mileage: 49920km-31018miles
09-Cent. Elect. -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: OK 0000
56-Radio -- Status: OK 0000
   Coding: 0000078
   Coding: 0000020
   Revision: 00H11001
   Coding: 0006786
   Revision: 00003001
   Coding: 0000000000
   Revision: 00020000
   Coding: 00D7B7
   Coding: 0730ED
   Coding: 000104
   Coding: 0016714
   Coding: 0001731
   Coding: 00000130
   Shop #: WSC 00000
   Coding: 410D00
   Coding: 0000003
   Revision: 00H15000
   Coding: 1377095
   Coding: 00000021
   Coding: 00000021
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 134
                    Mileage: 49921 km
                    Date: 2016.06.07
                    Time: 18:46:52
End-------------------------(Elapsed Time: 03:15)--------------------------
Excellent :)
You'll be limited to only having audio on the right side of the car unless you add two more wires between the BT module and Columbus. This will also resolve the final error for you.
If you want more voice control commands (navigation, radio, volume etc) then you'll need to do a little more work. The microphone will need connecting directly to the Columbus and then a wire adding between the Columbus and BT module. Probably not as worth while as the only voice commands I use are to call people.
Glad you got it sorted in the end.
could you point me in the right direction for the wiring diagram I would like to complete all of it then i can relax with this one,you have started something now with ross teck  I blame rustynuts and langers2k   :notme: oldtimer
For stereo BT audio you'll need to add these two wires:
BT module   Columbus    Description
pin 4       pin 11      Audio RF Signal Out +
pin 5       pin 5       Audio RF Signal Out -
For Columbus voice control you'll need to splice into the microphone feed.
Wiring for BT voice control (current):
BT module   Microphone  Description
pin 11      pin 2       Mic in +
pin 12      pin 1       Mic in -
Wiring for Columbus voice control:
pin 11      pin 9       Mic in +
pin 12      pin 4       Mic in -
Columbus   Microphone  Description
pin 1      pin 1       Mic in -
pin 7      pin 2       Mic in +
Once again thank you , oldtimer
