Evap Purge Valves N80 Fail
my understanding of purge valves in general is that 1/  it's fed "permanent" live (key on) from the main relay(easy to check)  and 2/ is then pulsed (to earth) thro' /by the ECU,  with some VAG stuff this will NOT happen with the tank >85% or<15 full  hope this helps
thanks
which one is main relay? is 458?
so far ......
1)EVAP purge valve resistance 26 ohms
2) I replaced relay 458,460,167
3) replaced all fuses
4) replaced Purge valve
5) checked continuity of cables from valve to ECU
no result ...........
  • Sponsor
If you run the car with the N80 unplugged, do you get a different error?
one new code ---after i disconnected EVAP purge valve and started engine .
01092 - Switch for Stowed Canopy (F171)
+ same '' 17833 - evap purge valve (n80) short to ground''
Edited by timz
I will try now ...
Edited by timz
 fixed
positive cable were touching frame of car
isolated cable and engine error is gone
thanks guys for you help .
