Evap Purge Valves N80 Fail
my scanner reads that : '' 17833 - evap purge valve (n80) short to ground'' I removed and tested valve it function opens and closes ....... Checked cables circuit looks fine .... any Idea what that might be?? ....... any help appreciated
  • Sponsor
Have you checked all fuses?
yes I did
wiring fault I guess  ---if so --- clear unplug run and check again  it most likely  still come back
I can clear with my scanner ....yes it does come back .
Wiring could of rubbed through somewhere, I would chase it and see where it goes
I tried it loops goes true firewall under the dash  connects to car Computer and finally connects to   valve
very tight spaces with other cables half of it I can't even see ...
If you can find out where the other ends of the wires go such as the pin on the ECU you can measure each core to the solenoid end for continuity and to earth with a multimeter
am afraid to touch ECU.
wot if I disconnect ECU and put on neutral end 6volts and try to find other cable that connects to it ?
If your not too happy fault finding and you have exhausted all your options then could you not find an auto electrician to have a look at it?
hard to find somebody that knows what he's doing .... skoda garage ask me 75 + 2 hours . Euros~ 250 -300
I guess valve ground short because it touches somewhere positive cable  so it is not zero it 2,3 volts and not closing and openning  valve .
You could always try just unplugging the connectors from the ECU and putting them back on again. Could just be a bad connection and the error code is throwing us off.
I will try tomorrow morning ..
Thanks for your help
hi
I disconnected battery and did continuity test with my multimeter positive cable from EVAP purge valve and fuse box in boot .
Am not sure if it bad or not ,five fuses reacted on test made sound on contact
is that supposed to happen or cables are twisted somewhere  and that is problem of my EVAP PURGE VALVE ??post-144553-0-25057600-1465322067_thumb.png
  • Sponsor
I think all five of those fuses are probably powered from the same point (fuel pump relay switched contact, at a guess). So if the fuses are all intact/OK, your purge valve 12V connection will appear to be connected to all five (via their common connection to the relay), so no fault there in my opinion.
any idea what that can be ?
and how to find ?
  • Sponsor
I'm not sure what you're asking with that last post?
Can you measure the resistance of the purge valve you have? Have you tried another? I seem to remember it should be something like 25 Ohms. Maybe yours appears to work OK when you test it, but the resistance is much lower due to shorted turns within the solenoid, and the engine ECU is unhappy about this?
yes I did 26 ohms
I removed and tested it opens and closes , resistance is 26 ohms .
  • Sponsor
Maybe a short-circuit to ground/chassis on the wire that goes to the engine ECU then?
I have only two errors ---'' 17833 - evap purge valve (n80) short to ground''
                                   "00022 - motor for warm-Air Flap; Center Console Right Rear (v201)"
​is that possible ? to do not affect other devices
  • Sponsor
Yes, it's possible. The 26 Ohms of the purge valve will prevent the fuse blowing even if the ECU wire is shorting, I think.
Warm air flap fault will be completely unrelated to this one.
I will check that tomorrow.
hi
I did continuity test on ECU connector , big one worked as shows with red arrows
but on shorter connector I can't find any contact to ground .
