Anyone knows what these OBD test codes means ?! CID:$01, CID:$06, CID:$08
Hi, I get these fails on ODB test. Can anyone tell which part/parts are failing ?
I know CID:$01 means Component Identificationn number 01, but which Component actually?
Thanks in advance for Your help.
TID:$02 CID:$01
- Lean to Rich sensor threshold voltage(constant)
Min: 2 703
Test result value: 968
FAIL
TID:$02 CID:$06
Max: 5 243
Test result value: 60 464
FAIL
TID:$02 CID:$08
Min: 1 311
Test result value: 991
FAIL
Lean to rich sensor - Lambda probe.
TID:$02 CID:$01
Min: 2 703
FAIL
TID:$02 CID:$06
Max: 5 243
FAIL
TID:$02 CID:$08
Min: 1 311
FAIL
Forgot to mention, Modell: Skoda Octavia 2002, 1U5, 1.6 petrol
The car can't start, the starter seems ok and goes round. The coolant sensor and spark plugs are ok. Any ideas?
Does the rev counter move when cranking?
