injector loom plug removal on vrs 2.0 tdi
Hi I have just joined this forum hoping someone can help me out I have a 2008 vrs 2.0 tdi that has a fault on injector 2 I have vcds and these are the codes I have (p1263 implausible signal intermittent and p1264 regulation range exceeded intermittent) what I would like to know is how the bloody hell do you remove the injector loom plugs whithout breaking them as I want measure the the resistance between the pins and injector body I only bought the thing 2 weeks ago and already regretting it also has anyone else had these faults any help would be really appreciated thanks.
There is a special tool to unplug the injectors without breaking the plugs. You can get away with a pair of long nose pliers if you are careful.
Has it had the injector recall?
Hi I think so I rang local skoda dealer and they said it was not on the list so I removed the rocker cover and  checked my injector part numbers (03G 130 073 T) so I presume they have been done its really bugging me as the car runs ok
It's more than likely that it is the loom that is faulty
Sent from my LG-H850 using Tapatalk
