2006 vrs tdi miss
Hi all i have a 2006 vrs tdi with starship miles 157.000 anyway it has an intermittent miss fire between 1500 and 2000 rpm pass this rev range and its fine.
parts changed up to now
turbo actuator
injector loom
It seems to be worse after a run ie when cold and making my 20 mile journey to work its fine.
after being stood 8 hours while at work return journey it miss fires.
It does not show a fault code
any advice would be greatly appreciated before i chuck more money at it.
I had a pd engined seat that had a similar issue it was injector related.
I'm sure they changed seals and it was great after that.
Showed no fault codes either
Edited by tubbytommy
Thanks tubbytommy i will try that fix next.
