Starter motor solenoid wire connector removal
Hi, can anyone help me with the removal of the clip holding the single wire running to the starter solenoid?  I can't seem to upload a photo at the moment but the connector is a round black plastic affair with some sort of red slider on the top.
Do I just slide the slider away from the starter motor (towards the wire) and then pull it off?  It currently won't budge.
NB I assume i can't upload a photo because I am a newbe?
Here's the promised photo
Pull the red tab back (looks like it is already) and then with your thumb pull back on the tab. Sometimes a push in first will help.
  • 4 weeks later...
Hi I see this is relatively new post. I'm having a starting issue with my fabia 1.4 8v, it bump starts not tried jump leads yet but when I try to start it by the key it gets a click then all the dash lights go out and come on again after I let key go. I'm giving the battery a trickle charge at the moment whilst at work. Also when I have bump started it there's no red battery light illuminating so I guess alternator is charging the battery.
