Fuse Panel
How do I gain access to the back of the interior fuse box? I want to add ignition controlled power for a dash cam and GPS and fuse #40 appears to be unused.
From what I remember, there are x2 torx screws holding the fuse panel in.
I don't think I've ever removed it to be able to gain access to the rear though, sorry
Hi,
40 and 41 are free - IGN. Switched Pos.
Remove Front cover - Un-clips
2x Torx Screws
Back cover un-clips
Have to wiggle out the fuseblock assembly and twist to get out through the gap available !
Empty Fuse positions
Torx Screws
Back of Fuses - removed from dash with back cover un-clipped
There is a Blue Bar that has to slide out from the end of the Fuse Block to allow Pins to be inserted.
Just by position 41 (not shown ?!)
Fuse block in-situ (viewed from below in footwell)
I think this is the right Fuse Block Socket Insert ?
http://www.vehicle-w...ays-6-3mm-blade
Otherwise try Skoda / VW dealer . . .
Pete
Photos from my DRL/Fog Retro Upgrade thread
http://www.briskoda.net/forums/topic/399096-retro-fitted-fog-drl-to-facelift-roomster-13-not-official-sk-method/
Edited by petrev
Thanks Guys! Very useful pics. According to my handbook, 40 is the rear wiper fuse (10 amp) and 41 is not assigned but is on the ignition. Just need to get the right socket insert and I'll have a go.
Cheers. :cocktail:
Mike
Cheers. :cocktail:
Mike
Hi,
My fuses must be different.
Pretty sure that is the right insert but best to check with Skoda dealer (or Vehicle Wiring Products).
The blue retaining bar was the key for me to add the fuses I needed.
Pete
Edited by petrev
Just remember don't cut off the 12v adapter plug unless you are adding a resistor to drop the voltage down.
Even easier if you use one of these
https://www.ebay.co.uk/itm/180735824927
General consensus on here is to piggy-back the rear wiper fuse.
I used this method to power dashcams in both my Roomsters.  Easy!
And I'm pretty sure the retaining bar is purple not blue.
That's just the job! Even after all the help from you all, I wasn't looking forward to taking the fuse panel out. I'm not as flexible as I was so it could have been a long, painful job with lots of swearing and drinks breaks. Adaptor ordered, should arrive mid week.
Thanks again.
If you don't want to chop the plug off your dashcam, you might want to use something like this:
http://www.ebay.co.uk/itm/1pc-12v-Female-Car-Cigar-Cigarette-Lighter-Socket-Plug-Connector-Plug-Cable-MW/201580220519?_trksid=p2045573.c100506.m3226&_trkparms=aid%3D555014%26algo%3DPL.DEFAULT%26ao%3D1%26asc%3D36886%26meid%3D0b39c5277fe04a7b8fb0f9744d6d3a1a%26pid%3D100506%26rk%3D1%26rkt%3D1%26
Mine fits under the dashboard end cover (open the driver's door to see it).  One wire goes to the piggy-back fuse, and the other goes to a suitable earth.
When routing the supply wire to the dashcam itself, I didn't try to feed the wire through the white A-Post trim.  Instead I tucked it under the rubber door seal, where it sits completely out of sight.  From here to the interior mirror, the wire tucks easily behind the headlining.
My thanks to those who kindly posted this information in other threads.  It helped to make installation in my Roomster easy and neat.
I've used a dual outlet with USB charging point mounted under the radio. A short run to the fuse panel with a 5amp fuse and I've linked to the radio ground wire. It's neat and works well.
