Power steering appears to go heavy on very slow speeds
Recently acquired Fabia Comfort 2001 plate with just 19k miles on the clock, appears to exhibit heavy steering (as if there were no power steering) at very slow speeds and is particularly noticable when parking or manourvering the car
At normal motoring speeds the power steering seems OK
Any indications as to the cause and remedies would be appreciated
PS:  I am very impressed with the build quality of the Fabia - but in view of the above I do hope that I have not bought a "pup" !
Lodestone
Do your headlights flicker when you're turning the wheel? What's your battery status ? What tyre size are you on and have you checked their pressure ?
The battery is a new Halfords , and I have just fitted  4 new Continental Tyres  185/60R 14 CO5 82H
The previous tyres (same size) were Chinese imports which I promptly took off due stopping/safety reasons
I have not checked the headlights scenario - but will do so
Lodestone
Any fault codes stored in the power steering pump?
Have you checked the power steering faulty thread?
Lodestone
I had exactly the same problem and all mine was very low on fluid,stupid place to put it under the battery tray which must be removed to top up.
Not on all engines, some the battery sits further back.
The battery is at the front RH side of the engine bay
There is a tray on top with electrical cables
Thee appears to be a cylinder underneath it with a opening nut on top
Is this the right one
If requires topping up - what fluid should be used ?
Lodestone
  • Sponsor
Green lid? That's the one. Find out if it's low on fluid before you worry about the type.  Can be stiff to loosen if it's never been off before.
Lodestone
Sounds like you're describing the clutch slave cylinder there.
As Wino says, the one you want is a green plastic lid that pokes through the inner wing. Most models require the battery and tray to be removed for access.
View from the top:
Dipstick reading:
Later edit:
The total capacity is 0.8L of CHF-11S/202 fluid.
Check the hydraulic oil level with the dipstick of the screwed lid of the engine pump aggregate reservoir.
Do not refer to the „MAX“ and „MIN“ markings on the reservoir to check the hydraulic oil level.
Edited by Alexandru
If the battery is good, I'd suggest a VCDS test on the steering angle sensor, and a load test on the alternator.
  • 10 months later...
On 7/1/2016 at 20:35, Lodestone said:
Lodestone
Hi there,
Spurred on from great advice from this forum - I thought I might make my next job to solve the power steering issue with mine, exactly as you describe. I took it to a garage to get a wheel bearing changed recently and asked them to have a look - but not fix because of costs! They said ECU reported low power to the steering.
My first thought was maybe to change the battery - but as I can see, your batter was new at the time.
Was wondering how you got on? I guess if the fluid is under the battery, it could be low : )
