Octavia MK2 2007 (preFL) Bluetooth/maxidot retrofit problem
HI!
in past two-tree weeks I retrofited MAXIDOT, COLUMBUS and bluetooth.
Bluetooth working with columbus , I can speek and dial numbers, Media over internet (phone) works too, but voice comands dont work and there is no phone menu in MAXIDOT.
On MAXIDOT menu I have Navigation and audio.
gateway
1K0 907 530K 0021
Columbus
3t0035680b H11
Bluetooth
7P6 035 730F SW2730 HW09
How I can get phone menu on MAXIDOT, and voice commands working?
VCDS found problems,
here is scan:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: Not registered 0011
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  9251
   Revision: --H06---    Serial number: SKZ7Z0G4057024
   Coding: 0050071
   Shop #: WSC 03029 425 89366
   VCID: 6AD1B30C3B66
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   Shop #: WSC 73430 790 00000
   VCID: 3F8732581064
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1Z0 820 047 D
   Component: Climatic PQ35   010 0301
   Shop #: WSC 00000 000 00000
   VCID: 346D6D742922
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004766903
   Coding: A1880F030004140000110D000000000000097F075C0000
   Shop #: WSC 73430 790 12345
   VCID: 6CDDB5143192
   Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 120207 022  0601
   Coding: 00055223
   Shop #: WSC 73430
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q2 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD11ETLT
   Coding: 0020786
   VCID: 3D7B48501A68
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
   Shop #: WSC 03029 425 68751
   VCID: 74EDAD7469A2
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 842 B    HW: 1Z0 920 842 B
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0G4057024
   Coding: 0000101
   Shop #: WSC 32072 001 10485
   VCID: 3669577C3F5E
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 170207F2001547
   Coding: 3D0F034007002302
   VCID: 2F676218C004
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 217986 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:17:35
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
   VCID: 3669577C3F5E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 B    HW: 3T0 035 680
   Component: RNS-MID       H11 4120
   Revision: AB001001    Serial number: SKZ6Z7J4147079
   Coding: 000004000400008100
   ASAM Dataset: ------------------------- ------
   VCID: 2F676218C004
4 Faults Found:
01042 - Control Module; Not Coded
            000 -  -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 217984 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:17:34
00873 - Bass Speaker Rear Right (R17)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 217984 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:17:43
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 217984 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:17:43
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 217984 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:17:43
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0953
   Coding: 0000116
   VCID: 38755944354A
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.068 H07 1806
   Shop #: WSC 73430 000 90108
   VCID: 346D6D742922
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Component:    KSG              0401
   Coding: 98D002007F2D8505084B010004CC
   VCID: 800571A4AD1A
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000116
   VCID: 39735C400E40
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   VCID: 2F676218C004
4 Faults Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 217984 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:17:34
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 217984 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:17:43
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 217984 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:17:43
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 217984 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:17:43
Address 77: Telephone
Cannot be reached
any help!?!?
What Bluetooth module did you fit? Not all modules work with maxidot in preFL and not all work with maxidot in fl.
Bluetooth
Sounds like the module is too new for the MaxiDot.
I had this problem, but, installing the PolarFIS+ unit solved all that, and gave some great extra features. It also allowed the HVAC and PDC display on the Columbus, without the pesky re-wiring :) :)
Wher is conecting PolarFis?
One offtopic question... can I install FL speedo with maxidot on pre-FL octavia?
