"Thrust bearing" sound" when in P and N - DSG
Hi,
When the lever is in P or N the gearbox make a sound similar to a worn out "thrust bearing". When put in D, S or R the sound disappears.
Any idea what can cause this?
It's probably a worn Dual mass flywheel failure.
Mine started making a noise in N and P which got worse over time (eventually becoming more of a rattling sound), until eventually it started violently juddering under acceleration at which point I replaced the flywheel.
If you try blipping the throttle in P or N you might be able to hear a slight rattle which is the early sign of DMF failure.
​Hi,
Thanks for your reply.
I am afraid it is that to. But luckily I changed it for under a year ago, so it is still under warranty.
I have also noticed that this noise only occur when the engine is cold. After some driving it is not noticeable.
Link to video: http://vid66.photobucket.com/albums/h261/grev1/WP_20160705_002_zps79vvpqpq.mp4
Edited by Kjetil1Z
I've had a chance to listen carefully to my DSG at idle, and I would say there is a slight noise in N and P.
My flywheel was replaced just over a year ago and has done around 10,000 miles.
