Hi i have this message on my dash. 2nd service indicator says that days to service are 0 but left 8000 km knowing that i did a full service 2 months ago and first service indicator says 295 days left and 7000 km. is it normal if so how can i remove it.
2013 Fabia MK2 Facelift out of warranty.
big-5853156d8c.jpg?v=1
Edited by Bashyka
When you serviced it did you reset the service indicator?
if you mean oil service indicator yes by pushing the 0.0 botton and turning the key ..... and i dit it again yesterday so i hvae on 1st indicator 15000km / 365 days left
Edited by Bashyka
Sounds right then.
You have two service lights, distance and time. If you just clear the one that is on with the above method the other will come on.
Best method to clear them correctly is with VCDS. As its part of any service to connect the diagnostic machine and check for fault codes resetting the light only takes a few seconds.
