Can anyone who has fitted a seat sport front mount help?
Hello just a quick question for anyone who has fitted a seat sport front mount intercooler after a remap did you have to get the map adjusted to suit the larger cooler and pipework? My car previously had a custom map with pd150 turbo putting down 195 bhp with stock side mount, now i have fitted the full darkside frount mount and pipework setup and it feels like i have lost power along whole rev range? Definetly no leaks it holds boost at 24 psi (used to be 26-27) cheers
Edited by Jay21Nov
You shouldn't of lost any power by changing the cooler. If anything the power should feel more constant than it used to as there will be no heat soak happening. The smic will of been heat soaked very quickly, especially with a remap and running a slightly bigger turbo. The front mounted cooler won't heat soak, or is highly unlikely to.
I can't fathom how you could of lost power...
JRJG
JRJG
That was my thoughts exactly it just doesnt accelerate as quickly especially 3.5k onwards, decided to get it dynoed hopefully this weekend cheers
Edited by Jay21Nov
The fmic will cool the air more efficiently and therefore power should be much more constant compared to the smic. So after a few flat out runs the power should still be coming on tap as it did the first flat out run. I don't see why it would drop off though?
Let us know what you discover!
JRJG
Have seen it on other cars,due to the larger volume of air that is in the new cooler and pipe work.
I've heard the same as coskev.
I guess you may need the map tweaked. Sure someone will be along with a definitive answer.
Cheers for replies will report back after dyno run
Ok got a dyno run today and turns out it made 20 bhp and held peak torque a lot longer in rev range happy days
I think it felt slower because it never made peak torque until higher in rev range but it holds it a lot longer so worth it in the end
20bhp? :D
**** me it must be quick!!!! :)
Whoops let me rephrase it made an extra 20 bhp so nows its at 216 :D
Edited by Jay21Nov
