Squeeky clutch
Hey guys
The clutch is squeeking every time I release it. Is this normal? My fabia city colour is only 6 month old.
Should I be worried?
Hey guys
If it is just the pedal a little squirt of WD40 or similar may sort it, try depressing and releasing the clutch pedal with the ignition off. If you have still got the squeak is it probably just the pedal. I had this problem and solved as above on my car prior to the Fabia.
And just be careful not to get any WD40 on the actual pedal itself.
Thanks for the advice,
So I spray wd40 on the clutch and fingers crossed I won't get it all over the interior!! Haha
WD40 worked a charm! its your one universal tool for everything....!
