Electrical Weirdness...
Hi all,
My Fabia has recently started acting up electronically. The issues are as follows:
- Convenience light doesn't go out when the doors are closed
- Car doesn't always give a warning sound when a door is open and a key is in the ignition
- Car locks itself at random when unlocked (even if a door is open)
I think this could be the convenience unit, but I'm not sure. Does anyone have any advice?
Yeh door lock micro switch I had this problem
I've got the same issue.
Annoying after you have sealed the doors.
Thanks guys. Thankfully I haven't sealed the door as yet, as I'm still tinkering with my audio setup. I'll have a look into which door is causing it, as the car seems to do this all at random - tonight it's performed flawlessly, but during the day it was doing the same as normal.
