PAS Problem, 00566.
Okay so what happens is around every 2 weeks my power steering will cut out (usually on roundabouts) and will not work until the car comes to a stop. As soon as I stop it works fine again with no problems.
The fault code I get is:
-00566
-Electrohydraulic steering, Operating no feasible
-Faulty signal
-Intermitant
I am thinking Angle sensor, but has anyone else had this problem?
I have checked Battery condition
I have Performed an alternator test
I have checked and topped up PAS fluid
Cheers Ryan
If there is the correct voltage at the pump and a good earth then it's a faulty pump.
