AIRBAG WARNING LIGHT
if i remove the battery on a 07 roomster. when i put the battery back on will the airbag warning light come on,
if so how do i turn it off
As long as the ignition is off the whole time, you should have no problem.
If the airbag light comes on you need VCDS or similar to clear it.
Do you no if it's the same on a 2007 Roomster as well.
Just changing back to a octavia as I missed my Lk dsg
I need to remove head unit from Roomster to octavia also reversing camera/ d r l s and every time I just leave the ignition off I bow fuse's. So was going to disconnect the battery instead
Why would disconnecting the battery bring up the airbag light? If your not working on the air bags you will be fine.
If you power up the car with an airbag removed, that will cause the airbag light to come on
Edited by SuperbTWM
Thanks for quick answer
Il give it a go tommrow
