SOS warning light from disconnecting ariel
Hi, I accidentally disconnected my shark Ariel on my 2023 Karoq.
I reconnected it, everything works fine including the SOS function and DAB radio. But I've got a yellow SOS warning sign and warning symbol on the dash.
Can/how can I get rid of the warning light?
Sam
Welcome to the forum.
I believe you need to clear the fault manually by plugging a suitable device into the vehicles OBD port.
Thank warrior. I've tried clearing the fault with a basic fault reader, but think I need a more advanced version. Any idea what level device would clear this? Thanks Sam
OBDeleven or VCDS I would suggest.
Thanks Dave, I'll look into it
What is your present fault reader, does it not have fault reset capability?
I have an old OBD dongle which links to an app on my phone.
A garage did have a go at clearing it with a more advanced scanner (was getting a new windscreen and the fitter did it off his own back), cleared it, but it came back a minute later. So I'm thinking I need the most advanced scanner/software to clear it.
Unless a fault is actually still present. Is GPS working correctly?
GPS is good, everything is working mate
