Control comfort module problem
In my skoda fabia II , few day ago problem with Centrol lock .
- No remote key working
- All door are opened cant lock it
- Trunk is closed can't open it
- Only driver side drive can be lock with manual key
I checked all fuses and relays with multimeter ,all are fine.
Here is VCDS log, any idea what is problem ?
Sunday,31,July,2016,17:59:32:46862
VCDS Version: Beta 912.0
Data version: 20091201
Chassis Type: 5J - Skoda Fabia II
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBDEC5J5AG011879   Mileage: 38880km/24158miles
Address 01: Engine        Labels: None
   Part No: 045 906 019 CL
   Component: 1,4l R3 EDC G000SG  4952
   Coding: 00105
   Shop #: WSC 01234
   TMBDEC5J5AG011879     SKZ7Z0I5427660
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: None
   Part No SW: 6R0 907 379 J    HW: 6R0 907 379 J
   Component: ABS 8.0 front   H06 0003
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0002151
   Shop #: WSC 01234 785 00200
Address 08: Auto HVAC        Labels: None
   Part No: 5JF 820 045 C
   Component: Klimaanlage         00.9
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 01234
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
            49-00 - No Communications
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 K
   Component: S1 AIRBAG VW51      0011
   Coding: 21297
   Shop #: WSC 01234
Address 17: Instruments        Labels: Redir Fail!
   Part No: 5J0 920 811 C
   Component: KOMBIINSTR.    V2802476
   Coding: 16103
   Shop #: WSC 00000
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 000J GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 01234
1 Fault Found:
Address 25: Immobilizer        Labels: Redir Fail!
   Component: IMMOBILIZER    V2802476
   Coding: 16103
   Shop #: WSC 00000
Address 44: Steering Assist        Labels: 6Q0-423-156.lbl
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10110
   Shop #: WSC 01234
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5J0 035 161 A    HW: 5J0 035 161 A
   Revision: R0007000    Serial number: SKZAZ4I0080445
   Coding: 05000400000600
Address 76: Park Assist        Labels: 5J0-919-283.lbl
   Part No: 5J0 919 283 A
   Component: Einparkhilfe        0001
   Revision: 00012000    Serial number: 09051100690325
   Coding: 0001110
End   ---------------------------------------------------------------------
Edited by naresh
I'd check to see of there are lives and earths at the body control module multi plugs. If there are I suspect the BCM has failed.
CupraLoon
I am new to this forum. I don't understand what you mean ?  Can you clarify little bit ?
Edited by naresh
Think he is saying the body control module is kaput broken or a connection issue
Ok, Service person changed CMM module to similar car and said problem in CMM in repair shop. I taken out CMM see visually everything seems perfect no burns,no corrosion ?
I still don't belive problem in module, is there anyway i can repair CMM or i have to purchase new ?
What I am saying is if you have no communication with a control unit but you have the correct voltages and earths at the plugs then the unit is broken.
