please help
hi. i played with my vcds and did what i shoud not do. i adapt the value of my injectors and now the way the engine work is changed from before. Is there are any posibilities to revers the adaptation?
thanks
What values/channels did you change?
in adaptation section I change the last number on all injectors from 1 to 0 channels 071 to 074
Not being funny,  but  can't understand why you have asked this question in the first place,  if you know exactly what you have changed. Just go back and simply change the values now back to what they were.
From the original post it sounded like a major panic because you didn't know the original values you changed from,  and wanted to know what values to restore.
Changing the values back to what they originally were would be the obvious thing to do before asking what to do in a new forum thread entitled "Please help ". If you are so unsure about how to use vcds,  I suggest you really don't play around with it.
Mike
I know it may sound daft but the problem is I changed back to original value and engine working different from the way it work b4 more noise and valves sound metal banging.
