accessing the BCM
Hi guys,
ive tried searching but to no avail, im installing some footwell lights in my octy and need to plug a wire into plug B (middle one) on the BCM. i just dont know where the BCM is and how to access the plug i need!
if anyone could shed any light or give photos then that would be awesome.
thanks
It's under the steering column more or less.
Remove the lower dash trim on the driver's side and put your head under when done so and you will see a box with three coloured plugs.
Black ,brown and white.
That's the bcm
oh easy then! thanks very much :)
To get to the BCM
Push the light switch dial inwards and turn to 12 o' clock position, it should then pull out. unplug it
Prise the trims off on both sides, you will then see 2x torx screws
2x lower down on the trim and 1x on the side
Thanks Eddie didn't want to bother you too much :P
Give Ed a PM he supplied my loom for a great price as well as install instructions
