Door Hinges Skoda Mark 1 2004 Plate
Hi,
Can anyone please help just tried taking off the rear os door, been using wd40 for a couple days.
I tried a T40 torx seemed nearest fit but was concerned was going to sheer head with torque used.
Does anyone have a idea of what bit I need to remove door hinge.
I accessed hinges opening the drivers door,any help will be appreciated.
Thanks guys....
  • Sponsor
T45 fits ours, but it looks like there's another bolt coming the other way, presumably accessed from behind b-pillar trim?
Try an impact driver.
Easiest way is to take the door off tbh.
13mm nut top and bottom, check strap and a couple of plugs and lift off.
Thanks guys for prompt response went with the spanner approach instead of Torx method.
