Brake parts help
Hi guys
Hope someone can help me.
I have a 2004 mk1 octavia combi 1.9 this 110 laurin and klement and need to change the front discs and pads.
I have been on ECP and their is different choices with disc size and also brake pad width and wondered if anyone would know which I would need as I don't have a clue.
Thank you in advance
Darren
Edited by Daz2804
If you look on the caliper it will give you the model - then if you hunt through the forum for brake disk size there should be plenty of posts that will point you in the right direction
A 110 is probably FSIII calipers (cast into outer face), and if so uses 280mm ventilated discs.
Thanks a lot guys will have a look today
280mm x 22mm discs with FSlll calipers
