VCDS query
 A little help please. I previously posted a question whether it was possible to adjust via VCDS the beam height of the front xenon headlights on my 05 octavia (I had to replace the front levelling module when the arm broke-after which it seemed low). Consensus was that it could be done by VCDS.
Tried to do so and failed. Can anyone advise how to do it or offer a step by step guide of sorts?? Many thanks.
You need to put the headlight levelers into learn mode using vcds.
Then you can manually adjust the headlights using the screws on the units.
It then uses this as the top position in the range.
Perfect thankyou
