Amundsen clock out by 1 hour
Hi anyone having issues with their Amundsen navs showing an hour early? Keep having to hold the power button down on unit to reset it which seems to fix it but annoying none the less.
Not an Amundsen but in my Focus ST I have the option to have the satnav display GMT instead of BST.
Is there a setting somewhere that you need to tick/untick?
Check timezone or dst feature. There should also be an option to stop it from automatic time adjustment based on gps.
Had the same issue, it was the DST causing the problem.  It was easy enough to fix in the car settings, think it was under setting and Time/Date.
That time of year, give it 2-3 weeks and the clocks will be changing again anyway :)
Yes. I cam turn off auto dst (which is probably the culprit and just manually set the time to "Eastern European" to move it forward manually to one hour bit something about doing that just doesn't sit right with me!
