Aircon pipe/ hose
Hi All
          It seems after changing the air-con pump & condenser last year the ( i think ) low pressure pipe which runs from the condenser to the bulk head is losing oil from one of the Ferrell's joining the rubber hose. Looks as thou it needs the full pipe from the condenser to the bulk head & seems a right Ba------d to change !!
       Any suggestions/ guidance very,very welcome or even the part number would help  :notme:
                                                       Paul
Lots of RTV silicone instant gasket, aluminum tape and a pipe clip!
Make sure you are sitting down when you price one up. For my last Passat, VW wanted around £450 for the pipe which went from the bulkhead to the condenser. Got one off ebay in the end for £30
And yes, it will more than likely be a nightmare to change. You will also need the appropriate 'O' rings
Edited by SuperbTWM
