Car Problem
Really could do with some help!
I went out in my car tonight all was okay until I pulled out of a junction and it started juddering like I was going to stall even into third it was jumping and then the engine management light started flashing. When I turned the car off and then back on revs kept dropping. This was stationary. Then when ive drove back the engine sounded as it was was struggling and I am now struggling to gain speed and the revs are a lot higher at lower speed than it should be.
Any thoughts would be much appreciated
Go on, give us a clue, which engine is it?
It a 1.2 engine 03 plate fabia
Sounds like a MAF sensor problem
Can you get it diagnosed?
Coil pack, flashing CEL indicates a misfire, there will be a code to tell you which coil pack needs changing.
