Next Issue >< oil pressure warning light
 - So i thought this was related to my MAP sensor... however car is running great now new MAP is fitted. However after driving the car for a while, and usually when on boost the oil pressure warning light comes on with 3 bleeps, its not a maintenance light.
  • Sponsor
Should be (or be equivalent to) VAG part number  038919081K according to here.
If it looks like it is leaking oil, definitely replace it, even if it doesn't seem to be, it's probably worth the gamble for £12.
When was the oil last changed? Is there any whiff of diesel on the dipstick?
Check the wiring first I would,could be tight somewhere and when the engine moves it's most it's stretching it :)
Oil changed last month.
 It always seems to come on just as the engine gets warm, so i guess as the oil becomes thinner... i hope its not the oil pickup.
