Another tow bar Q
I have looked but cant find, is there a pictorial guide to fit a tow bar I do not need to know about the electrics just where all the bolts clips studs etc are to get the bumper, lights etc off
Dev
www.pfjones.co.uk/witter/SK26.pdf
  1.
  2.
Generally the installation guides for tow bars tell you how to fit the tow bar and what parts you need to remove. They do not tell you where every single nut, bolt, screw or clip is located because that would mean they would have to to strip down hundreds upon hundreds of cars they make tow bars for.
The best guides you will get are ones you find on forums from people that have done the job but they aren't that common as I found out recently. I had full intentions of making one when I fitted mine but it was a time consuming job when taking apart a car for the first time so I didn't bother in the end.
If you do get stuck though all you have to do is ask because there are a lot of users on here more than happy to help and have more than likely done the job before
