esp light on no power octy vrs 2006 help
car has always run fine.then tonight after a 3 mile journey to my parents,got back in the car to go home epc light and engine light came on,car sounded ruff likes it running on 3 cylinders smells of unburnt fuel and no power  even when i press the pedal to drive,used a cheap code reader just to see of i could remove the lights,engine light goes out but esp light stays on and car still has no power.i have not had time to check as it was late and dark.any help on what it could be before i take a look would be a great help as there seems to be quite a few different problems with the same fault
car is a 2006 octy vrs,it is mapped and decatted ect,but this was done a few years ago,just to rule that out.any help thanks in advance
car has always run fine.then tonight after a 3 mile journey to my parents,got back in the car to go home epc light and engine light came on,car sounded ruff likes it running on 3 cylinders smells of unburnt fuel and no power  even when i press the pedal to drive,used a cheap code reader just to see of i could remove the lights,engine light goes out but epc light stays on and car still has no power.i have not had time to check as it was late and dark.any help on what it could be before i take a look would be a great help as there seems to be quite a few different problems with the same fault
sorry should say ecp fault in tite
it sounds like a coil pack has given up,thats what happend on my old mk1 vrs 1.8t it ran on 3 cylinders and went into limp mode,did you get a fault code ?
I don't condone piracy but there's VCDS copies on fleabay for around £40 (or £300 for genuine).
They work great and stop the guessing game when it comes to fault lights being lit.
i have the fault codes and they all seem to point to the throttle body if some one know"s if they think it could be the problem before i go and buy a throttle body
001688
000291
000546
008482
005497
any one have an answer before i buy a throttle body
any one have tried a throttle body but still the same and still the same codes
