H&R Lowering Springs
I have got a set of brand new H&R lowering springs, bought the wrong weight for my car... so looking to sell them so i can get the right ones..
they are for any Octavia mk2 upto 1020KG max front axle load (will also fit other cars of the same platform)
they are H/R29261-1
these are a 30mm drop over standard (so less on the VRS)
looking for £100 for them shipped or collected from teesside area
cheers.
price drop... will take £85 for these ...
Will drop my 1,6 tdi?
hi mate, sorry didnt get notified about your post... you will need to check your cars max loading.. it should be on a plate on the passenger side door pillar and look like this
http://i38.photobucket.com/albums/e122/jrappai/Da%20Car/vRS/2F450C0C-orig.jpg
the 1 and 2 marked numbers are front and rear loading
mine is a 1.9 and is 1050kg, so i would expect yours to be less. so should be fine with these springs
Thank you for the help. My front axle load 1050 as yours so the springs won't drop it properly. Sad ????
they should actually sit a little bit lowerat the front than rated.. if thats what you want then its up to you i guess
Edited by Memphis Raines
What rear rated? My estate is 1150 max
