Time to warm up - CR VRS
Hi,
Since having my FL VRS I've noticed it takes quite a while to warm up, even for a diesel. 10-15 minutes is not irregular now it's cold in the mornings (and I keep it in a garage overnight) and this is with gentle driving on quick roads - 60mph for about 6/7 minutes before I hit around 5 mins of traffic then up to 70.
My Fabia VRS never really took that long, just interested to know what is 'normal'.
Cheers,
Harry.
Diesels take longer than petrols to warm up and produce heat from the heater.  My 2012 vRS CR certainly takes a lot less than 10 minutes to produce warm air even when the temp is less than 7C and I am driving at 30-40mph.
A low coolant level could cause you problems.
Are you talking about the water and oil
Temps?
Mine always takes a long time to warm up now the ambient temperature is lower, although the air comes out of the vents warm reasonably quickly.
If you mean the temp gauge then in the winter it'll take about a week!!!...well it feels like a week in my car. I can drive 20 mins to work at 30 mph and the gauge doesn't move!!! It's been like that from new....plus it means the aircon is freezing :(
Yes I am aware they naturally take longer to warm up but what I was trying to say was when compared to my Fabia VRS Mki it seems to take a lot longer.
Temps?
Yeah, I am. Oil temp rises steadily behind the water as expected. Just takes a long time like you say!
Thanks, sounds about normal then! Case closed :P
Cheers all.
