Backward Heater Controls
Disconnected my battery to fit my dragon tuning box and now my heater controls are back to front, any quick remedy or is it a recalibration job?
cheers
Ben
With other VAG cars I've owned, once the battery has been reconnected you need to turn the ignition on but not start the engine, let all the lights / dash light up and settle down, then turn off take key out, wait a few seconds and then away you go!
Try this procedure and see if it cures the problem.
Is it the temp control that is backwards?
If so it will need re calibrating with VAG COM or similar.
