Rattle from the front end!
Hey guys, on my 03 furby vrs i have a rattle when i have very low revs, its not the gear lever cables! has anyone had this before, it almost sounds like an exhaust mount is loose! Is this common????/?
Many thanks in advance.
Any mods?
does it happen at certian revs? or is it only when in gear?
i have a, seat strut brace, pd160 airintake, and only at very low revs eg when pulling away!
Righty...
check for things rubbing on the strutbrace.. the airbox or the engine cover are the common ones...
also i had a issue with the cupra air intake, the part that connects to the scoop at the front of the car wasnt a tight fit and would rattle ALOT at just above idle speed i took it off and applied a few layers of electricians tape to pad out where they clip together... this cured the rattle for me.
