P0340 - P0341 - Powertrain Faulkt codes
Hi,
I have a 1.6 TDI which has has the following error codes pop up. This is just after a couple of months of having the NGR valve replaced is it linked at all? Also on the dash also the TCS light on the dash is this also linked? When the car does start it runs smooth no hunting. I have just given it a surface 2 weeks ago and all looked good then (oil and filters). Any ideas?
ECU reports no current faults
Pending Fault Log
P0340: Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
P0341: Camshaft Position Sensor "A" Circuit Range/Performance (Bank 1 or Single Sensor)
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
End of report.
Small update. Decided to pop home and swap cars just in case!!!! Took me about 3 mins playing and the car started on the way back it cut out and the ignition / coil light flashed here are some more faults that popped up. Also just so you know I got the car started back up. I should point out while running the engine was smooth in high and low revs and ideal. Yes I did get
Current Fault Log
Pending Fault Log
P0016: Crank-Cam position correlation
B2AAA: Unknown code - More information may be available on the web
Edited by MRB007
  • 3 years later...
Hello there. Did you ever find the cause of these faults? I have an 07 plate petrol vrs and my faults are similar
See here...
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
724/P0340 - Camshaft Position Sensor (G40): Malfunction
Possible Symptoms
- Malfunction Indicator Light (MIL) active
Possible Causes
- Wiring from/to Camshaft Position Sensor (G40) faulty
- Camshaft Position Sensor (G40) faulty
- Timing misaligned
Possible Solutions
- Check Wiring from/to Camshaft Position Sensor (G40)
- Check Camshaft Position Sensor (G40)
- Check Timing
