Fabia Jerking
Car : Skoda Fabia Classic 51 KW TDI
Fuel : Petrol + CNG
Model : 2008
at the the time of driving after 3-4km running Red Oil Message Blinking and beep again and again still car engine off.
after that upto 10-11 km AC cooling automatic Going off, after restart the engine cooling Start.
within whole day if car running 35-40km then car continues jerking on Both fuel after 35-40km. I think car is leaving the current.
I show car in Skoda Service centre they scanned and saying O2 Sensor problem will be there , they are not sure about it.
then what will be the exact problem.please anyone knows help me out.
Hi Sagar,
if you look and post in the Fabia 1 section, im sure some very keen people will help you out.
the "off topic" area is for genenral day to day chit chat :)
Moved
You may have a faulty oil pressure switch, it's quite a common fault.
AC cooling fault may be caused by the condenser overheating due to an electric fan not switching on, check that both engine fans are coming on.
Jerking after 35-40 km may be caused by excessive cylinder head temperature causing 'pinking' and misfiring due to borderline overheating, I suspect the ECT sensor or the secondary fan motor.
Thanks  For response Mr.Sepulchrave
02 Points resolve Oil & AC ( Oil Switch and Fan Changed ),
Now car is to much jerking after EPC Light (after 20-25 km running within a day ), please suggest the exact solution.
Thanking you in anticipation.
