What is this paste like material on my engine?
https://youtu.be/KATC0m7jvdk?t=41
Here's an unrelated video of my engine bay, what's the grey paste/glue type thing just to the left of the oil lid/cap? Best seen at 40 seconds
It was there when I purchased the car
Has the belt/chain been changed?
Regards
Thanks for the reply
I don't think it's an oil leak as it looks like someone has resealed the area
That is what i meant 'resealed', because the casing was split and needs resealed.
Ah right, OK thanks, I'll see if there are others who've had the same
Regards
​It seems the sealant they use when closing back the camshaft chain covers (the black plastic part on the left of the block, is the top part of it). I had my chain replaced 2 years ago and a bit also oozed out, although not as much (I guess the mechanic who did it in mine was a bit neater :) ). [i have the same CBZ engine as you].
