Indicator wiring
Hi All,
Looking for a hand with possibly sourcing a wire. Is there a permanent +12V wire that is only active when you indicate regardless of which side?
Weird request I understand. But necessary for a project.
Jerry
Not that I'm aware of.
You can design some electronics that takes feeds from either the indicators or indicator switch and gives you a 12v line. Alternatively, you can tap into the CAN-bus and watch for the 'indicator on' message.
Whats the project you're trying to do?
Edited by langers2k
Easy.  Just tap off each line with a diode/rectifier.
Install after market flashing lights in the front indicator area for an ambulance responder that "auto cancel" and whenever the indicator is switched on.
I thought it might be a canbus job. If need be I'll add the override wire direct to the indicator bulb +12V so it will cancel if the indicator is flashing but may flash inbetween.
Or you could consider a delay off timer fed by indicator feed.
