Warning lights on
Hi I've got a problem with my Octavia 2009 2.0ltr vrs tdi ABS ESP tyre pressure warning lights on skoda garage have told me it's the ABS pump module need to know where it's located in the engine bay and does the module remove separately from the pump or dose the pump and module remove as whole unit. Thanks any help appreciated
Edited by Tallman58
Needs moving to the main section.
What do you mean the post needs moving?
This is the technical section for posts on how to's.
Welcome to the forum.
On my vrs it was on the passenger side of the engine bay bulkhead under the battery area,you can get a repair kit for the pump,the pump has to be removed from the car to strip it down to fit the repair kit & you have to bleed the braking system as you have to disconnect the brake pipes from the unit.
