Radio code help!
I parked my Fabia in the garage for a couple of months and went to start it up and nothing! Jump started it and off and running! Battery checked and holding a charge.All good so far! This morning on the way to work, I turned on the radio and nothing..... Just displays 'SAFE' and some numbers.I wasn't given any codes when I purchased the car and now am stuck! Is there an easy fix to this please?! Thanks!
The code should be stored in the cars ECU hence no code, there is a procedure for getting the radio working following a SAFE lockout.
Usually goes along the line of, switch on ignition, do NOT start engine, switch on radio and wait a few minutes for the code to be sent to the radio and you should get sound.
