Help ! DRLs blown electrics !
Hi
I really don't know what I've done here
I fitted 2 new DRLs LED from Hids direct supposed to be 580 21/5 they didn't appear to work so bought conventional bulbs from Halfords and drives side all ok
But passenger side yikes the DRLs work but no parking/side lights and the rear lights have stopped working in that side to
I've swapped bulbs changed the 2 blown fuses that went but still rear light cluster is dead, brake light works
Anybody got any ideas
Hi
It'll be a fuse most likely, I know you've replaced 2, but check each one, suspect a dodgy LED has caused it to blow, I've mucked around with different bulbs in the past, if I recall I would check fuse 22 isn't blown (think it's called light switch) if that's fine check other fuses
How are you checking fuses? Visually or using a meter? I'd start by checking every fuse in the fuse box with a multimeter set to continuity. Remove each fuse and check across the terminals
Sorted thanks
4 fuses blown !!
21,22,11 and another which I can't remember but it was labled headlamp but did passenger side drl and rear light cluster
Blooody mad how can replacing a bulb cause so much grief !!
Thanks anyway
Glad it's sorted :) me and Updown share your pain, I went through a few different dodgy bulbs so did fuse replacements multiple times :D
  • 9 months later...
Thread resurrection!
This is the exact same issue I have just happened to fall upon.
I have checked all the fuses and all appear fine.
I did replaced 22 as it had blown, so now I have the NS parking lights working, (they weren't). 21 an 11 are both fine.
Any know what other fuse/s to check? I don't like randomly pulling fuses!
Apologies for a question on my first post
Edited by rowlers
corrections
Things could get interesting, just checked the newer manual and looks like the fuse layout has changed.. I'm assuming yours isn't a newer model as fuse 22 is the horn :D
Check fuse 4 which is for Daytime running lights
2015, and my fuse layout IS different from the manual posted on here. I can get a photo of the layout in my manual if it helps?
Edited by rowlers
corrections
Edited by rowlers
update
Try fuse 45
3 hours ago, Hyphons said:
Try fuse 45
Nope, not that one either!
But I have found it.
Both fuses 21 and 22 and blown. I must have been blind when I first checked them, only finding the 21 blown the first time.
All working now, only problem is that I only had a 10amp fuse left. I'll need to pick up a 7.5amp as soon as I can.
Thanks for the help.
Edited by rowlers
Reading this thread ( and similar ones on the same subject) I realise what a lucky boy I was back in 2013 when I bought my new Citigo. I fitted a pair of LED DRLs from HIDs Direct...absolutely no issues at all, simply plug-and-play. They're nearly four and a half years old and still as bright as new...as I say, lucky!
