Help With my Skoda Octavia 2 MK2 comby
Hello i have a Skoda Octavia 2 1,6 diesel (J623-CAYC-engine code)
and today i have 3 ligts on dash bord first is dpf on, second chek engine, and third coil flashing .
Anebody have some ideeas
A friend of mine help me with a diagnostic and here is error code
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 8810
   Revision: --H43---    Serial number:
   Coding: 00114016032400080000
   Shop #: WSC 30924 001 1048576
   ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
   ROD: EV_ECM16TDI02103L906023LP.rod
   VCID: 7F06ED0FE66D7AE058F
1 Fault Found
16848 - Diesel Particulate Filer
          P2458 00 [175] - Regeneration Duration
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 173670 km
                    Date: 2056.14.28
                    Time: 18:15:58
Thanks!
If i activate a service regeneration(with vcds interface) the engine is working normaly not limp mode (warning light are still on) .
How can i reset tis errors and after that to try again a service regeneration .
i use a vcds interface to scan for error codes and here is a part of log file
FOR Engine
VCID: 7F0A9BD3E6EEDBC624-802A
1 Fault Found:
16848 - Diesel Particulate Filter
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 175084 km
Date: 2017.01.26
Time: 09:50:19
Readiness: 0000 0000
