Octavia 2016 Fog as DRL (none xeon) verification of coding code
Hi dudes ...
Hi dudes ...
As I have installed tasty fog lamps, Philips Ultinon H8 LED I would like to use them for DRL instead of those ugly yellow H15 on low power.
Any one tried to code it and can verify the below coding. I’m not a VCDS shark but can manage to the most if I’m sure of the coding.
The below is found in this forum.
Foglights as DRLs
Controller 09 - Central Electronics
16 - Security Access - enter 31347
10 - Adaptations
I haven't tested this, but I am assuming your front foglights are also coded as cornering lights. This means we have to assign a 3rd function to the front fogs. If you haven't coded cornering fogs then look at the post for the cornering fogs and set the values of function B to Tagfahrlicht (Daytime Running Lights).
The following channels need changing to a value of 'Tagfahrlicht' (Daytime Running Light)
(8)-Leuchte12NL LB45-Lichtfunktion C 12) from not active  to Daytime running lights
(8)-Leuchte13NL RB5-Lichtfunktion C 13) from not active  to Daytime running lights
The following 2 channels need to be changed to a value of 100
(10)-Leuchte12NL LB45-Dimmwert CD 12) from 0  to 100
(10)-Leuchte13NL RB5-Dimmwert CD 13) from 0  to 100
How to disable the DRLs on non-Xenon cars
I'm fairly sure the adaptation to disable the DRL for non xenon cars is in the VCDS sticky at the top.
Looking for people who can cornfirm its working.
