1.4tdi Greenline - things to look for?
Hi all - moving house in 5 weeks time to somewhere 5 miles out of town. Been on the lookout for a little runaround for a second car and tracked one down locally tonight. It's a 2008 Fabia 1.4TDi Greenline with 92k miles, one owner but well used.
I'm interested to know if there's anything in particular which I should be looking out for tomorrow? I've had Octavias over the years and currently run a Superb, but know very little of Fabias unfortunately! Any help much appreciated :)
 Check that it has good service history, this model keeps popping up on Auto Trader/Ebay as non runners with what appear to be oil pump problems. It may just be that I notice them more as we run one, but suggest searching on this forum and also googling. Does not appear to apply to the "normal" 3 cylinder versions - 1, 2 and 3 models - around this time. Could be how they are driven as higher gearing than std 1.4's could result in lower revs causing torsional shock through oil pump chain.
Edited by KeithCheetham
Much appreciated Keith - many thanks :)
I hope someone can confirm this, but I seem to remember the Greenline has a DPF.
I would be interested to hear that indeed!
With thanks to m8t for posting this link in another thread:
http://www.dpfproblems.net/cars-without-a-dpf/
"Skoda clearly identify its DPF equipped models with an options code in the service book and a sticker in the spare wheel well. A code of ‘7GG’ indicates that a DPF is fitted, and ‘0GG’ indicates that the car does not have a Particulate Filter fitted."
​Hope this helps :)
 There is indeed a DPF on the 1.4 Greenline - I have had to replace the DPF differential pressure switch on ours, there being one made in USA? and one made in Malaysia. A while back and cannot remember what issues it caused.
Went to see the car and made an offer which was accepted, subject to it passing a new MOT without any problems. Does indeed have a DPF. Needs a bit of a tidy up here and there but should come up well enough. It's black & I always said I wouldn't have another, but it's only a second car :)
First job would be to get cambelt and water pump done if anyone knows best place to source these from? And if the headlights are as bad as I hear, then bulb recommendations would be helpful! Many thanks.
Lol - must be worth a look then :)
