Limewire vs Firewall
:confused:
Cannot download from Limewire which I suspect is due to Firewall settings.:thumbdwn: :thumbdwn:
Running win XP with zonealarm firewall
any pointers???
Limewire help?
Limewire help?
Everyone a classic................:rofl::D;)
Already tried all the suggestions under "firewall settings"
Zone Alarm is pretty good at blocking everything that trys to get though... but sometimes it's a little too effective :thumbdwn:
If I were you, I'd disable Zone Alarm when when using Limewire, but make sure that you have the XP firewall switched on... as I've found that doesn't conflict with Limewire. If you don't want to use the system firewall, mine also worked fine with McAfee for a long while...
Chris
It may not be of help, but I have only ever had problems with Limewire when daughter has been on msn and it seems to totally nack my pooter, I have used Limewire for about 12 months and have had no probs , and I am a computer idiot. Good Luck !
If I were you' date=' I'd disable Zone Alarm when when using Limewire, but make sure that you have the XP firewall switched on... as I've found that doesn't conflict with Limewire. If you don't want to use the system firewall, mine also worked fine with McAfee for a long while...
Chris[/quote']
Tried this and still no joy :(
Have you ever used it before?
If yes, on your current machine?
Have you recently updated the Limewire version?
Buy a router :D Software firewalls suck.
All sorted now.
Plenty of reading and folowing instructions on Limewire forum :)
Thanks for the help chaps :thumbup: :thumbup:
What was it, so we can all mock you, did you have the cable plugged in the wall... :D
Chris
