Revs on start up
When I start the engine up first thing in the morning the rev needle reads 1000rpm and sounds like it is struggling at idle, then after about 3 minutes of warming up it drops down to 900, is this normal?? The needle doesn't flicker it remains on either 10 or 9
That's normal I think. As the temp rises the revs reduce to normal tickover.
I agree, it's normal.
I've noticed raised rpm in 3 cases:
1) cold outside when you start the car;
2) it's hot outside and you turn on the AC;
3) DPF regeneration. It's unlikely to start when the engine is cold. And anyway 900 rpm sounds more likely to petrol rather than diesel.
