gasoline
Is it wrong to use gasoline octan 80 in felicia 97 carb engine 135mpi
Yes, it is. Minimum recommended octane number (RON) for Felicia on carburettor or Felicia 135 MPI is 91. I know that Felicia is cheap to run but don't treat it like it is a tractor...
By the way, 135 MPI means Multi-Point Injection. Your engine has a carburettor, basically it is a Favorit engine (factory engine code is 135). You can't have both injection and carburettor, unless you took an 135 MPI engine, got rid of all injection related parts then installed a carburettor, a mechanical fuel pump, a distributor, an electronic ignition, a single ignition coil, etc. That kind of 'hybrid' engine doesn't even has an official code.
Iam sorry Ricardo,my engine is 135 not 135mpi....what about it???
I answered your question. Don't use gasoline lower than 91.
I thought there is different between 135 and 135 mpi .
Many thanks for your advice.
It is. I have explained it too.
