Car locking issue + Warning light
Hey all
I'm a new Fabia owner - purchased a 59 registration Fabia about 6 months ago.
I've just encountered two issues today after not having used the car for three weeks.  Firstly - my warning light for door open stays on despite all doors being properly closed.  Secondly - my car key doesn't work properly - it unlocks the car, but doesn't lock the car.  I'm forced to use the manual key turn on the car handle for the car doors to lock.
Any idea what the issue is?
Many thanks in advance for your replies!
A faulty door lock module I'd assume,
common fault across the vag range,get it on vcds to see which one but probably the drivers door
the battery on your fob may be going flat,usually unlocks the car when going flat but doesn't lock it,but I'd get the dirt module sorted first and go from there
Broken cables in the loom between the door hinges coming off the multiway connector are common.
There are several threads on this.
