VCDS help
Is there anyone with a VCDS in the Croydon area that can help me modify the Maxdot km/h to mph reading, please?
If so, please PM me.
You might be better off asking this question on the VCDS forum.  The procedure to get the Maxidot to display mph has been discussed a number of times on this (ie Yeti Mk1) forum: a search should turn it up if you don't have it to hand.
Thanks. Although, helpfully, it was on this forum that I discovered what a VCDS is and the fact that it could work magic – it's not a discussion I'm after; it's a magician.
If you don't find anyone closer then I'm around an hour away in Folkestone
If you were to have looked at the link @ejstubbs had posted you might have noticed these two threads:
- https://www.briskoda.net/forums/topic/262215-list-of-vcds-owners-previously-known-as-vag-com/
- https://www.briskoda.net/forums/topic/224376-vcds-owners-map/
Either will help find local VCDS owners (or magicians) :)
