CV Boot (Inner) Replacement advice
Hi there guys.
Car has been sat over Winter over at my mothers.. Been abusing a little Corsa :D
Anyway, noticed the subframe was a bit greasy and upon further inspection notice that the Inner CV Joints are both knackered.
Cant find much on the forums in the way of guides/tips for the inner CV Joint.
I presume from a few videos I have watched that it is easier to remove the Driveshaft as opposed to replacing in situ?  So loosen centre spindle/nut, ball joint out, rotate wheel to one side, slide out outer CV/shaft - lost when it comes to the inner!
Any input is appreciated! :D
I think its just 6 M14 Spline bolts that keep it in place?
Edited by MidWalesVRS
  • Sponsor
6 M10 spline bolts I believe, 2nd item 13 here.
Are they reuseable and is there a torque value? Cant seem to find one.
With it being a later model, it'll be fitted eith the 36mm 12 point hub nut I presume? Which will need to be replaced? Is TPS best place to search?
  • Sponsor
(Official/erWin) Instructions for the drive flange - CV bolts:
replace after each removal
 initially tighten to 10 Nm,
subsequently tighten
crosswise to final torque:
M10 screw:
50 Nm + 45°
M8 screw:
20 Nm + 180°
You're right about the hub nut, also a replace item.  6Q0407396B, I believe.
I imagine lots of folk re-use the driveshaft bolts, cos the cost mounts up if you need a dozen of them (e.g. for a gearbox removal/clutch change).
Edited by Wino
Top man Wino.
Seen a few conflicting theads with regard to the hub nut.. upon removal should the driveshaft come out freely.. seen threads talking about copper hammer taps and removal tool.
  • Sponsor
The first time removal is attempted since factory build will be hard, as I understand it, because they are bonded in with something Loctite-ish. If it's been out before it'll be easy.
Lovely jubbly! Off to TPS i go.
